My multi-room DVR tapes well except for HBO programs. Sporadic issues with both audio and video. How can I fix this?
@jazzy8 wrote:My multi-room DVR tapes well except for HBO programs. Sporadic issues with both audio and video. How can I fix this?
It seems a specific frequency is being affected. Look for a bad or non-MoCa 2.0 splitter, bad coax, or a problem with the ONT. It could also be an issue with HBO, if you can check with a neighbor, see if they have the same issue to see if the problem is only in your house.
