I've been trying to program my remote for over a month now since I've had service. I called technical support they said they couldn't do anything but send me a new remote(incase of malfunction). I don't think thats the case.
I have a CURTIS HDTV ( not curtis mathes) . The company that makes my TV is http://www.curtisint.com/ .
I have the new FiOS remote for just TV capability(not dvd or vcr or other stuff). Model VZ P265v1 RC.
I've tried 082, 083,084 codes , they don't work. And I also tried the "use brand code" method. doesn't work either. Please help!
Dear Warz2k4,
Have you attempted to do the search for a code? Below is a link to a video how to. It will allow a search of all codes on remote (there is about 300). If the TV is compatible with remote it will use one of the generic codes available. Please let me know if that helps. Thanks
Unfortunatly those videos will not help. He has the 2 function remote, not the 4.
Warz2k4,
Did you follow the Code Search Method to Program the RC in the booklet? If not, try that first. If you did, there is nothing more to try. That tries every code the remote knows. If none of those codes work, then the remote simply will not work with your tv.
If that's the case, you have 3 options.
Dear Spacedebris,
What model remote does he have? Thanks
@warz2k4 wrote:I have the new FiOS remote for just TV capability(not dvd or vcr or other stuff). Model VZ P265v1 RC.
I will investigate further. I am pretty sure that the search steps are the same for the model you currently have. Thanks for your patience.
Thank you for the replies, I really appreciate it
Anyways, yes i've tried the code search where it sends a new code to the box everytime I push the "Play" button. Nothing works. I tried this random code method bout 5-6 times, it usually ends at a stop where the "red light" blinks continously about 3-4 times. On the manual I read online for my particular remote, it says CURTIS is 082, I've tried that, while pushing up/down channel , as well as volume, nothing worked.
I don't really like to use 2 remotes, nor use a universal remote controller 😞
Can someone investigate further whether CURTIS even support this type of programming function?
I would like to discuss the issue over the phone. Please go to the secure link below. Enter the Name, Address, Phone and Email. Reply back when completed. Thanks
I have filled out the form you linked.
Please let me know when you plan on calling(hour-hour), I'm currently unavailble today till like 8-9pm EST
Hello Javier, i received all your voicemails last week. Sorry I've been insanely busy and going on 5 hour sleep/day due to 4exams this week/3 finals. Is there anyway you'll be availible tomorrow(tuesday at 12pm) to call me? Or possibly Thursday(12pm)? Please reply asap, thanks. -- Ricky
