I just replaced my router with a new Verizon router. Everything is working except the TV Central Remote DVR. It keeps coming back with the device is not responding. I have reset the box and still it is not connecting. After replacing the router, is there another step I'm missing? Do I need to have remote DVR reset? If so, how?
Correct answers
I did not hear back from anyone, but just tried and my Remote DVR is now working. I don't know if they fixed my specific problem, or a more general problem.
Jim
I have a question. Are you getting your guide and widgets etc on your dvr box? Are you able to watch Video on Demand on it?You may need to power cycle your dvr. Basically turn it off and unplug it for a min or two. Plug it back in and turn it back on.
Hopefully this will fix it..
Lori
Verizon Telecom
Fiber Solutions Center
Yes, try disabling then enabling the remote dvr. Hope that works.. Let me know.
Lori
Verizon Telecom
I am having the exact same problem. I can no longer program my DVR from my computer for about the last week or so. It always says that my STB is not responding. Sometime during the last week, I pressed the reset button on my router because I was having some pixelation on HD VOD. Someone from Verizon told me to do that. The pixelation has greatly improved, but now I have this remote DVR problem. I don't remember if I had this problem before I reset my router. Everything else works. I called Verizon tech support on Sunday. They said they would get back to me within 48 hours. So far, no one has called back.
I did disable remote DVR in the settings, then re-enabled it. That has not helped.
I am having the same problem. Has anybody come up with a solution?
Yesterday I contacted Tech Support. They tried a few things, but then opened a ticket. I am waiting for a response from them before doing anything else. Based on the one response, it doesn't sound like disable/re-enable will work.
Jim
i tried unplugging and disabling and re-enabling. no help. Let us know if what they have you do works.
Jim
I am having the same problem. Called teck support and got the same result (tried a few things and said they'd put in a ticekt). Seems to be a common issue. Any other solutions?
