I have a Fios voice remote and I have went through the self programming steps several times and the remote will power on/off the cable box and TV and will control the volume of the sound bar but it will not power the sound bar on or off.
any help or guidance getting this remote to power on and off the sound bar would be much appreciated
thanks
@Kipper1012 wrote:Ok I switched from SPIDIF to HDMI and tried reprogramming the remote, same result grrrrrrrrrr
Sometimes when doing the manual programming you have to skip the first option that changes the volume. There are sometimes two codes for the same manufacturer that will work the volume, but not other functions. Try skipping the first one that affects the volume and see if there is a second.
@Kipper1012 wrote:I have a Fios voice remote and I have went through the self programming steps several times and the remote will power on/off the cable box and TV and will control the volume of the sound bar but it will not power the sound bar on or off.
thanks
Is the soundbar connected via HDMI? If so make sure CEC is enabled on the TV and the TV input control is on in the Fios box video menu. You may also have to manually program the remote for your soundbar by removing its programming, then using the manual programming method instead of the auto programming method.
No it is connected via SPIDIF to the tv
@Kipper1012 wrote:No it is connected via SPIDIF to the tv
You'll have to reprogram the remote, adding the soundbar manually as an audio device at the end. You'll be asked during manual programming if there are additional audio devices, say yes and find the brand and model of soundbar there.
After you've paired your Fios TV Voice Remote to your set top box, HDMI connected TVs and Audio systems should automatically be detected and be controlled by your Fios TV Voice Remote.
In some cases, you may have to manually enter your specific TV and Audio equipment information. Follow these instructions to do so:
Yes I did that several times and it will only controls the volume of the sound bar , it still won’t turn the power on and off.
ive tried inputting the model number manually and also letting the remote find the correct code. Neither one worked
@Kipper1012 wrote:Yes I did that several times and it will only controls the volume of the sound bar , it still won’t turn the power on and off.
That makes me wonder if the power command in the remote for the soundbar is programmed for CEC control, not a direct IR command. If it works the volume, it must be depending on CEC to turn the power on and off and you have the correct programming on the remote. Sorry I don't have a solution for you other than using HDMI.
