Soundbar Connection - Set Top Box
Benns
I recently purchased and received the Verizon Soundbar.  Does this replace the Set-Top Cable Box or can the Soundbar be used together with the Set Top Box?  If so, how does that connection take place?
Correct answers
Re: Soundbar Connection - Set Top Box
clem21
MVP MVP
MVP
Soundbar works with the box, not instead of it. Go HDMI from the box to the soundbar, then HDMI from soundbar to the TV. You should have had instructions included with the soundbar.
https://www.verizon.com/support/knowledge-base-240465/
clem21
MVP MVP
MVP
