I recently purchased
Philips Fidelio Premium SoundBar Home Theater HTL7180/F7
and was wondering if anyone could help with the Fios remote control code. I have tried all the Philip's codes and none of them seem to work to control the sound bar with the given Fios remote control. Having 2 remotes is very cumbersome, so please help! What should I do?
Get one of these:
http://www.amazon.com/Logitech-Harmony-Remote-Control-Silver/dp/B004OVECU0
Good Luck.
@ZL710 wrote:I recently purchased
The code for the soundbar most likely isnt in the fios remote so you won't be able to use it. Fios remotes are outdated with old codes. As said your best bet is to purchase a universal remote that will work with it such as the Logitech Harmony 650 that was posted. You can get them very cheap on ebay. They work with any device. I have one and love it.
