I have seen some other posts mentioning that they are no longer getting dolby sound - but they seem to be connecting to soundbars... I currently am working OK - but it seems my optical cable might be going bad/have a loose connection (I keep losing sounds and have to "jiggle" the cable). Since I have to get to the back of my boxes, I was thinking to swap out my current connection (video component and the optical sound) to to the Yamaha receiver to just run a single HDMI. Anyone else running that way - and will I still need to replace the optical cable - or does just HDMI between the two work just fine?
@BrianHarg wrote:I have seen some other posts mentioning that they are no longer getting dolby sound - but they seem to be connecting to soundbars... I currently am working OK - but it seems my optical cable might be going bad/have a loose connection (I keep losing sounds and have to "jiggle" the cable). Since I have to get to the back of my boxes, I was thinking to swap out my current connection (video component and the optical sound) to to the Yamaha receiver to just run a single HDMI. Anyone else running that way - and will I still need to replace the optical cable - or does just HDMI between the two work just fine?
Shouldn't make a difference whether you go HDMI or optical. Both can carry Dolby Digital, just make sure it is enabled in the Fios box settings and in the recievers input menu.
Thanks - on my to do list tomorrow - will try w/ just HDMI and give it a shot - thanks!
