Verizon Mobile Remote Help
nichthefish
After a certain amount of time, my mobile remote will disconnect with my top-box and I'll have to reconnect it. I checked the FAQ's, and it says if you want to change the period of time after which the mobile remote disconnects, go to Settings and then Auto Exit Timer. I do not have 'Auto Exit Timer' in my settings, and I have looked almost everywhere, even outside of settings. I updated, so I have the latest version.
I have a Droid Eris, and downloaded Mobile Remote from the android marketplace. I really would like to be able to change this. Does anyone know how?
Re: Verizon Mobile Remote Help
TonyaD_VZ
Contributor - Level 3
nichthefish,
We have escalated this issue for resolution.  We will update you soon.
Thanks,
Tonya D.
jonnyc1
This is even worse on the iPhone.  Any update on how you can adjust the mythical "Auto Exit Timer"?
