Correct answers
as someone else suggested, I clicked on "Feedback" and left a message for Verizon Support about the DVR problem, and today I received an email back: "Thank you for your feedback. We looked into the issue and it has been fixed. If the problem persists, please call 1-888-553-1555 and the representatives will be happy to assist you."
And it's working fine!!!
Thanks for recommending leaving feedback, and thanks to Verizon for fixing it remotely! 🙂
I ran into something similar because the DVR would change it's TCP/IP Address and not udate the forwarding rule in my Router via UPNP. I was able to make my STB use a Static Address with a DHCP Reservation and then enabled and re-enabled the remote dvr feature on the STB to update the Forwarding Rule and it has been ok ever since.
To make the DHCP Reservation on the Actiontec:
- Select Advanced
- Select IPAddress Distribution
- Select ConnectionList
- Select the STB from the List and Edit
- Check off the Static Lease Box
