I had to give back my Note7 twice, it was an awesome phone. The S7 Edge replacement was great, until the update, now all I have is issues.
1) S7 Edge will not charge wirelessly. I can have it on charger entire night to maybe get a few % up. Under Battery-Advanced Settings- I have the Fast Wireless Charging button on, As soon as I place it on the wireless charger, that button turns itself to off. When I take it off the charger, it goes back on. I loved the convenience of wireless charging and have a lot of expensive charges that I can't use now. How do we fix this. I see a lot of others with this issue. I can only charge with a cord now. Won't charge in car at all even with a cord.
2) Battery life, dramatically dropped. I used to have to charge my phone once every day or so, now the battery drains quickly whether I am using phone or not. I looked and app usage is all normal range.
3) When texting, the suggestion box comes up black with suggested words also in black, can't see them, pointless.
4) I had this awful rainbow screen saver that literally lit up the room at night, thanks to these boards, I found out how to change that.
The wireless charging issue is my main complaint, I don't want to turn off the phone when charging as I can't get calls. Why should I have to when my phone worked and charged perfectly before. Whatever the update fixed I wasn't using, I don't run a lot of apps or stream anything, normal usage drains the phone
