Last Friday (30 Jun), my S-7 Edge was shutting down apps randomly and seemed on verge of a crash. I powered it down and then back on and subsequently downloaded the most recent update (don't know which one specifically). As soon as that update loaded, the phone began power cycling off and on every 30-60 seconds. It is never on long enough for me to even power it down gracefully...thus it keeps going for about 4-1/2 hours until the battery expires. I can then charge it, but if I power it up, the cycle begins all over again. I tried restarting it in "Safe Mode" which had no effect; the phone still cycles off within about 30 seconds (and the screen is frozen until it powers down). Is there another way to correct the issue, or am I[Removed]? Barring another solution, I fear I'm relegated to doing a factory reset, but right now, I can't even get to that point without the phone restarting first. Anybody have a PhD-level idea? Thanks. -DBH
inappropriate content removed as required by the Verizon Wireless Terms of Service
Message edited by Verizon Moderator
