Recent security update and I'm having usual battery drain. I already checked apps. No new additions to apps. Cleared cache partition. Turned off battery draining apps. Still unusual drain?
I would do a complete phone backup with Smart Switch or what every you use to backup your phone then do a factory reset. Then go back into your phone and check the settings for things like play store updating on wifi only and other settings that take data.
