Hello,
I am no longer getting LED (blinking) or a VM notification sound on my Samsung S9. All I get is the icon in the status bar showing VM. The notifications used to work fine. I can't say when they stopped.
The phone is NOT unlocked. It's running Android 10 and Verizon is my carrier. I am using the basic VM app that came on the phone. I am not using visual VM. I cannot think of any app(s) I installed that may have affected voicemail notifications. No custom LED color apps, no custom notification or profile setting apps. No custom themes or launchers. I don't install and remove apps frequently. I mainly use the phone for email and texting.
This is so frustrating! I know there are users out there, smarter than me that may have a solution?
I am not new to cells. Been in IT for eons. PLEASE PLEASE do not suggest the basics - turn on voicemail notifications etc. Trust me, I've been through all those settings numerous times. Everything that should be enabled is. Permissions are correct. I've tried turning VM options off, restarting the phone then turning the option back on etc. Tried clearing storage data in the VM system files and on and on.
I am looking for some advanced ideas to try to resolve the issue. Maybe delete a corrupt settings file, how to force a reinstall or restore of the VM system (if possible). Some ideas like that.
I'd like to avoid a factory reset but I am almost certain that is what it will take to fix this.. There must be a file or process that contains settings that is preventing VM notifications.
I can't imagine there is anything Verizon can do to my account that would resolve this VM notification problem but I am willing to call them if anyone has had luck calling Verizon for this VM issue.
Any advanced suggestions would be greatly appreciated.
Thanks!
