If my fingers are even slightly resting on the left hand side buttons ( volume up down) and the select button, it will require me to lift my hand so that there is no contact in order to go further with a selection. It is as though that slight pressure prevents other choices.
This is super annoying. I have to constantly readjust my hand position but where else do you rest your hand when you're holding it in your left hand? Has anyone figured out a fix for this problem or has anyone had this problem?
