I just got my new Incredible and was wondering if my BB Strom ac and car charger will be compatabile with it. They are Micro usb. Don't want to void my warranty right off the start.
It'll work...
dabubbakin wrote: It'll work...
correction, it might work, but the worst thing that will happen is it won't charge it. it will not hurt it, though.
the long answer is: different phones use different pins to take power from to charge, my ipod and omnia 2 can be plugged into the same charger, but my omnia 2 will not use some of the ones my ipod will. the USB cable part itself is not the difference, just the charger part.
