long story short.... open ticket 2850980. Cellphones will not stay linked to extender. Must get very close to register, only if the phone stays within a foot will it remain linked. This is the second extender I've tried... When linked, calls work ok, coverage is great. If I'm linked and not on a call I can go quite a distance and make a network extender call, no problem. If I'm on a call it will stay linked. Problem is when phone is idle, whether 4 feet or 40 feet after about five minutes the phone will revert back to over the air coverage. Lights remain blue while this happens. Internet connection is DSL with static IP.
There are no router issues... and I have tried specifically opening the ports (thinking maybe they were closing) and also tried puting it on the DMZ... routher is DIR-655 Dlink.tried switching phone to 1X only, no effect. It seems that the phone has a preference for the over the air signal which in my location varies between EV and 1X at various strengths depending where you are in the house. Cellphones tested are VX10000 and LG 8300. VX10000's have latest firmware.
Need HELP.... Verizon Network People!
