I have owned the Pantech Jest for over a year now and really like this feature phone.
when i first got it it began to malfunction after the 1st week.
went through all the frustrations and problems many of you have had with this phone, but I liked it so much i refused to give up on it.
verizon sent me a new battery, a replacement phone, - nothing seemed to work.
FOR THOSE OF YOU WHO HAVE HAD CHARGING PROBLEMS/PHONE DYING PROBLEMS WITH PANTECH JEST:
here's what I discovered :
SOLUTION 1:
Fully charge your new phone BEFORE any applications, updates, downloads, etc. Just let it fully charge!
SOLUTION 2:
NEVER, NEVER, NEVER let the battery run down to dead or even to 1 charge symbol (I'll call it a "block").
the jest must be charged regularly WITHOUT letting it die out comletely.
i now, regularly charge my phone at 2 blocks and NEVER have a problem with it anymore! I have charged it with 1 block left and it still charged. However, If you get down to 1 block and let that go for a while - until almost dead - it will NOT take the charge.
You will know this because when you plug it in, it will NOT progressively flash the charging blocks but show all FOUR blocks at once as though it is fully charged. when you unplug it, it dies almost immediately. (sound familiar?)
SOLUTION 3:
Should you happen to let the battery die down completely, or if the battery is not taking the charge - (must have progressively flashing blocks) - you will need to buy an external battery charger. I bought mine from Radio Shack for about $30. Ive only used it a few times as I rarely let my phone die out comletely. But when I have, IT WORKS EVERYTIME!!!!!! You place the battery in the charger, lining up the charges, and let it fully charge. you will get a blinking light showing that it is taking the charge. it will be fully charged when the light stops blinking and is just constant and green. Put it back in your phone and voila! the phone works again!
REMIND YOURSELF NOT TO LET THE BATTERY DIE DOWN,
REMIND YOURSELF NOT TO LET THE BATTERY DIE DOWN....AND IT WILL ALWAYS TAKE ITS CHARGE PROPERLY.
(get that External Battery Charger from Radio Shack as your backup, should you let the battery die down)
(if you try and update your contacts, download applications BEFORE you FULLY CHARGE your phone, you will also have problems)
have a nice day
