I am constantly turning off or on the voume on my TB. The location of the Volume Rocker is always in the way.
Is there a way to lock or disdable it?
I've tried RingGuard (free on the app market). It doesn't do exactly what you (and I) probably want, but it does require you to acknowledge and accept any volume change it thinks you are making. I wish there was a widget that locked it "in" when it was set as I'd like.
Thank you everyone for the information. Additionally, I provided steps on how to set the volume below:
Lena,
Your reply adds no useful information.
Since the design put the Rocker where it is, we need a way to lock it.
Heres the app that should work for you...
http://www.appbrain.com/app/volume-locker/com.hourdb.volumelocker
RingGuard does the same thing. Both apps make you acknowledge a volume change with a pop-up. I (and others IMO) are looking for a way to set our preferred volume level, then "lock" it at the setting until we "unlock" it to make a change without all the unnecessary pop-up yes/no acknowledge prompt.....I find myself "resting" my finger on the volume rocker with a little too much pressure while in landscape mode constantly. At least if I don't acknowledge within my 2 second setting window it auto reverts.
How hard can it be for HTC or Verizon to provide a way to lock this oversized, poorly placed button out?
There seem to be several of these, but I've been using Volume Control + Pro for a couple of weeks and it seems to be working very well with no problems or battery drain. I'm hard of hearing and have set all of the controls to high except for the media volume which I left unlocked so I can adjust to the volume of different songs.
I've tried adding a link, but am having trouble doing it, but just search the market for that app name.
