I have just installed the new update for my Droid X. Now the green LED light on the phone doesn't blink for missed calls, texts and so on. Anyone have any suggestions??
My suggestion is to do a search or look on the first page of this forum. There are MANY posts about this.
Things people have done to get their LED light to work (I'll just sum it up for you here):
- Clear the Cache of the texting, calling, email, voicemail apps (Settings - Applications - Manage Applications)
- Download an app such as LightFlow (lets you customize the LED notifications)
- Battery pull while the phone is on
- Clearing the entire phone cache (also do a search and you'll find step-by-step instructions of this)
- Hard reset (search this as well for instructions)
Also, I'm sure a Verizon rep will post on here as they do on EVERY LED post and say that this is a KNOWN issue with GB and that they are currently working on a fix and have several flags in their system for this issue.
I just recently worked with VZW CS about this issue. I was told it is a software issue with the 2.3.3 update. So we have to wait it out for another OTA update or find an app to fix the issue. For more information, see the above post.
