My Droid Incredible 2 has a loose battery door.
It appears to snap into place normally but it is NOT a snug fit.
It is very loose on the top right, bottom right, and left middle. Sometimes, the cover will even pop off on its own.
I have ensured there is no interference whatsoever.
There is no damage to the phone. It has never been dropped and has worked really well for 3 weeks with the exception of this issue (and bluetooth connectively, but that's another story)
Over on Phandroid, several others have reported this issue and have spoken with Verizon - since this is a warranty issue, Verizon has sent then replacement battery covers in the mail. Obviously, a brand new phone should not have issues like this.
http://androidforums.com/htc-incredible-2/334846-battery-door.html#post2697424
Was wondering if anyone else has had this issue and if Verizon has truly confirmed this is a known issue (as indicated in the link above)?
Thanks!
