I have just had the replacement 9550 two days and it is having the same issues that the original 9550 it replaced. Here's the issue: For an unknown reason, i can be using my phone or checking messages, even just picking it up and touching any button to wake up handset....it resets, red light stays on and it reboots itself. it has a new OEM battery never been dropped(if fact it has a OtterBox Defender case), never gotten wet or anything i can think of. Only have a few apps on device, the phone is more for work than for entertainment.
These are the same issues the original phone had, mostly unexplained resets. When I talked to VZW, the rep thought it was possibly a software or other issue since I have not dropped it or anything i did to it or any cosmetic marks, etc. They got me out this replacement overnight, but it is having the same issues 2 days from being unboxed. The original was still under warranty and I have total equipment coverage. Here's the issue...if I call for another replacement, and it has the same issues as this replacement and original, is this going to just be stuck with hoping i get a replacement that works? I am a year away from an upgrade and really don't have the $$$ for a switch to another type of smartphone. Any words of advice or ideas that could help me out? Thank you guys in advance! - scott
