The manual states the battery indicator will show as solid green when fully charged, though mine only shows solid green for about a second and then turns off.
Got the device yesterday, plugged it in and the green light was blinking. It said to charge it for 5 hours prior to first use. However, when I came back home 1 1/2 hours later, there were no indicators illuminated.
I unplugged it and plugged it back in - the battery indicator was initially red, then went solid green for a second or so, and then turned off - no indicators lit.
I then the device up via USB, powered down, disconnected, turned back on and tested access with several devices, for about 10 minutes or so. Then turned off and went to bed.
This morning, I plugged it back in, assuming it would at least take a little charge and blink for awhile. It did the same thing it did last night. The red came on, then the solid green came on for a second or two, then no lights.
So, the question is, is the green solid light supposed to stay lit, as long as the device is plugged in?
