I got the Razr and do like it a lot.
But that battery drains like there is no tomorrow!!!
I am using the "Smart Actions" app but it still draining.
To give an example, I can fully charge the phone at 9AM and
by 10AM it is down 80% and that is with 2 very short calls, and the smart action working..
I has used thee task manager to shut down apps after their use.
I have stopped using a "live" wallpaper.
I have no idea what to do next...
Any help out there???
Thank you
