Ok Straightly My fascinate's usb part is broken I think.
If i connect to charger, it is not charging and also if i connect to my comupter,
usb turn off messgage never comes up and it never charnges.
what should i do?
Try another charger, try another outlet. If that fails, get a warranty replacement or new phone
Its very frustrating to have a device that's not charging. Please pull the battery and retry. Is there any corrosion or build up where the battery connects to the cable? Please PM me and I will troubleshoot this issue with you.
Thank you
