I can receive emails and can browse but I can't send any emails or pictures. I get a "Connection Problem" when trying.
What can I do?
Thanks
ac1007,
You'll be glad to know this problem sounds like it can be easily resolved! Since we know the data connection is fine because your browser is working. I would like you to remove and re-add the email account to the device, then test the outgoing email. Also, check the camera settings to ensure the resolution is low enough to send properly.
Please advise any fix or progress so I and the community can continue to assist!
Thank you!
That worked. Thank you!
