You say your phone charges fine with your roommates charger.... Sounds to me like you have a bad charger. Have you tried your charger on your roommates phone? If his/her phone won't charge with your charger, it's almost a certainty that your charger is the problem.
Good luck!
trfalsone wrote:What app or type of app would you think could be causing the problem? I don't want to uninstall or factory reset my phone...if I wanted to do that I would just get a replacement phone. I do have an ATK on my phone...
From your home screen, press menu>settings>about phone>battery use (unless Moto moved it). This will give you a list of apps with a percentage of how much battery they have used. Also an app called system panel in the market will help you to monitor what is using system resources. I would also personally recommend uninstalling ATK, though not all users would agree with me. Maybe try turning off autokill and see if that helps. I do agree with dirkbonn, though, that it sounds like a bad charger,
I'd say google android task killers and do some research about it, then make your own decision cause, you're right, some (like me) say they're evil and the bane of any android users existence, and some say your phone won't work without it. Could be (assuming you're using a third party battery monitor app) that ATK is messing with it, but your issue sounds worse than that. Also, if I remember correctly, Moto phones only report battery % in 10% increments, so that could be the problem. I'm thinking that you need to do some more investigating into what is killing your battery and, if nothing apparent pops up, call tech support and see if you can get a replacement.
trfalsone wrote:Oh ok.....im confused about the ATK some say get rid of it others swear by it. As far as my charger they are brand new just got them.
trfalsone now i'm gona ask a question what kind did you get was it Motorola OEM or a off brand. an as for those task killers get them off your phone. here's a good one to use Its called Task Pannel i have it. An use it alottt there is a Paid version or a free version there both good to use i like the paid one better its $2.99 give it a try.
trfalsone wrote:After doing a little research...I believe that I need my original charger from Motorola, but I can't afford another charger of more than $30. I don't know what to do. Ill try calling Motorola in the am and see what they suggest.
trfalsone can you afford a little over $14.99 im gona pute a link on here its of the Moto travel charger an its $14.99 plus a little S & H
this charger works good why do i know i've got one an was using it on my X when i responded to your post. so if you can afford it. Its a good charger. Here's the link if you need a car charger i'll get you a link for one of those as well.
http://store.androidcentral.com/motorola-micro-usb-rapid-travel-charger/5A17A3049.htm <<< right click your mouse on this link.
Update: I went ahead an pute the link for the Car charger on here as well so you can look at both of them.
http://store.androidcentral.com/motorola-micro-usb-high-performance-car-charger/5A47A3044.htm <<< this one is for the Car charger.
Good luck too ya an i hope one of these will help you out B33
you can pickup a blackberry charger if the plug is the same as the droid X - I have one I keep at work and while it doesn't charge as fast, it still works like a champ. Only drawback is that it was $20
I would also try booting into SAFE MODE and plug in the charger and see if you get the same results. This would rule out 3rd party Apps ...
To boot to SAFE MODEL
- Power Off
- Press & old MENU button (far left button)
- Press POWER UP - continur holding the Menu button
after about 1-2 mins the phone will boot saying "SAFE MODE" in lower left corner
Plug in your charge and see if it behaves the same way. If it does NOT - e.g., charges properly - you have a 3rd party App sucking the life out of your battery.
To get out of SAFE MODE, just power off/on as usual.
PS - I use the MOTO Car charger - it works great .. much better than the Verizon one. Maintains a 100% charge when in my car even when running a ton of apps at the same time.
Good luck.
(PS - i am of the camp to remove the ATK ... you really should not need it and unless you really know what you're doing, can cause more harm than good .. YMMV)
The reason i stress on using OEM chargers for devices like the Droid X is there desighned to work with them when for instance your using a Motorola Home OEM charger when it's done with its charge say it takes 2 hours to charge an X at the instant it's reached 2 hours that charger dips down to trickle charge an its safe to leave the phone on it. Were as a non OEM i would stress leaving it hooked up to the device no longer than when its done charging. an the voltage going into the device is critical as well like my Moto chargers all three of them pute out at 5v @ 850 mA. You use a charger that puts out more mA's its going to burn out the charging final in the Device an when it does how you gonna explain how your phone got damaged. i would'nt want that on my shoulders i rather pay a little more an have peace in mind i'm using the right charger for the device it was intended for. B33
trfalsone wrote:Thank you all....im still waiting for my new battery to come. But now I am also waiting on a motor charger. I called them and they are sending me a new one. Hopefully that will work.As far as mu chargers go....the one from Vzw. Output is 5.0V and the quikcell is 750mAh. So im not sure all that talk confused me....lol
Ehhh, don't think that 750mAh charger is gonna be sufficient. However....try it and see. Try charging your phone for a couple of days and see if it works.
As I said earlier, I get my OEM chargers from Ebay. Do a search in the "cellphone accessories" section of Ebay for "Motorola OEM chargers. You should see a boatload of vendors selling the charger for 12-14 bucks new and in the OEM packaging.
But try the one they are sending you first.
Geri O
trfalsone wrote:I have a DROID X and have been having issues for the last few weeks with my phone staying charged and charging. I have had both my home and car chargers replaced. Everytime I charge my phone it says that it is charging bit the battery level does not improve. When I use my roommates charger it charges fine. Also the battery says I have a certain % of battery left then the next minute it goes down 10%andthat that happens whether it is charging or not. I don't know if a certain app could be causing this or if the phone is junk and I need to get it replaced. Its getting annoying that I have to charge it every night and can't be away from home because I wont have a charger. PLEASE HELP!!!
Hi there!
I'm sure this has been frustrating for you, but it sounds like it you've gotten it resolved. Going off of everything you posted, it does sound like a battery issue to me. Especially after you stated charging it seemed to drain the battery.
Please advise if this is correct once you've received the new battery!
Thank you!
If that happened after getting a NEW battery then the phone itself has a problem. I'd be pushing for a replacement phone
It always amazes me that people will spend money for $6-$700 without giving it a second thought, but then will go cheap on the charger. The OEM one is $19.95 but they found one on ebay for $12.95.... for a whopping $7 savings.
I always purchase the OEM. Sure they cost a little more but I figure, why take a chance for $5-10 bucks. If it ever comes down to my charger fried my $600 Motorola phone, and they ask me if I was using an off-brand charger? Nope, one of yours! According to Jaque Clouseau..... the case is soll---ved! :smileyhappy:
you can purchase an original motorola charger for less than $4.00 on amazon. I bought the stock battery new for just over $5.00.
http://www.amazon.com/Motorola-SPN5504-SKN5004A-micro-USB-Charger/dp/B004EYSKM8/ref=sr_1_1?ie=UTF8&qid=1315096613&sr=8-1
i hope it`s ok to post a link.
galaxie500fb wrote: you can purchase an original motorola charger for less than $4.00 on amazon. I bought the stock battery new for just over $5.00. http://www.amazon.com/Motorola-SPN5504-SKN5004A-micro-USB-Charger/dp/B004EYSKM8/ref=sr_1_1?ie=UTF8&qid=1315096613&sr=8-1 i hope it`s ok to post a link.
Well there you go... cheap and OEM. Best of both worlds. Maybe this another positive thing to come from the manufaturers move towards a universal charger connections for phones.
Actually $3.48 and free shipping with orders over $25. That free shipping is a BIG thing for those of us that live in Hawaii. Otherwise shipping kills us!
Hello trfalsone,
Wow! It sounds like you have done a great deal of troubleshooting!! Thank you community, as usual, you ALL offered great suggestions such as troubleshooting the battery, troubleshooting the charger, removing advanced task killer and anti-virus apps and also Safe Mode.
I am curious to know whether or not the new charger is working for you.
If you have tried the brand new battery and the brand new charger and you are still having problems with the phone charging, then it is most definitely time to replace the phone.
If you need assistance with doing so, please PM me & I can order a replacement phone.
i have the original charger for both and neither one works. i believe it is a glitch in the droid htc 2
Could be the Mini pin on your Device. But i would Go to the Local store an have them hook one of there's into it. And see if it Works..b33
