I returned my first Droid because of a terrible echo on the other end of all my phone calls. Having the same problem with this phone. Any ideas?
I'm having a bit of this problem too. Though only one person has complained about it so far.
I suspect there are others, maybe many, with the echo/feedback problem. We bought three Droids and all of them have this problem. Called tech support at customer service and they indicated that it is a known problem and that Motorola/google/verizon are working on a fix but nothing promised soon. Could be a month before there is a software download. That's what they said. They suggested powering off occasionally for a few minutes as that seems to have a short term benefit. That seems to help a bit but it comes back in our experience. Not possible to carry on a conversation with all the echo and feedback.
I found that if I reduced my in call volume, it would reduce the echoing for the caller on the other side to something barely noticable. Once i raised the volume again, the echoing became much more pronounced.
The good thing is that even with the volume down at the minimum value, I could still hear them clearly.
Thanks for the reply. Did support indicate to you that it's an issue with all MotoDroids or it's just some of them? If it's a software download that fixes it, I would think it's an issue with all of them.I ask because, of course, I'm trying to determine if I should go for #3 or just return the phone and go back to my trusty Curve.
My Dare had this problem too. Verizon failed to acknowledge it since it didn't happen on every call and refused to replace it.
At least they are admitting there's an issue now.
Any of you try to disable voice privacy? It's under Settings:Call Settings:Voice Privacy.
Over the years, I've read about users on other phones experiencing echos because of this feature. Turn it off.
I have exceptional voice quality with my Droid. No echo with clear sound quality.
Edit: Don't forget to power cycle the phone after changing the setting.
Just bought the Motorola Droid (A855) yesterday and it has the echo issue. Caller or called party says that they hear themselves and I hear the conversation where some sentences are chopped off. It is very irritating.
I understand (looking through other forums) that there will be a software maintenance release coming out Dec. 11 to fix this and other issues. Some have suggested power cycling the phone, others say to reduce the volume for the call to help alleviate the echo. I have found that neither are really a work around. So getting another phone is not going to help. The HTC device is an option.
This issue appears on the Verizon Wireless Product Technical Bulletin for Nov. 5, 2009 and is described as "Far End Echo".
I'm having a terrible time with the Echo. A few people have even asked me to hang up and call back. I will try turning down the volume as was suggested. Hope it helps.
However, I will not be keeping the DROID if it isn't fixed before the 30 day return date. I love the Droid and apps, but after all, it's main job for me is as a phone, and if it doesn't work, I'm not going to keep it.
i'm having same problem. but this helped me bit.
voice quality is much better after turning off and back on the the speaker while in use.
I had the echo too until i turned off hearing aid and privacy. Calls are nice and clear now.
Same problem with echo reset with *228 turn off hearing aid compatibility no ech today will let u know
I just bought my Droid last week. I haven't had many phone calls, but I'm having the echo problems too. Extremely frustrating! I turned off Voice Privacy and Hearing Aids and reset my phone as suggested in previous posts. I'm hoping this solves the problem because a phone that doesn't receive clear phone calls is not going to do me any good.
I have read on other sites that an update is coming out by Dec 11 to fix the problem. I also read that you can power off the phone and it sometimes corrects the problem. Finally, you can reprogram the phone by dialing *228 and selecting 1 the first time then repeat the procedure and select 2. Not sure why more help is not provided by Verizon. Must be a PR issue.
