My Droid X is rebooting over and over again, I have removed the battery only to have it return to rebooting/repowering over and over. Has this happened to anyone else and how in the world do I fix it?!?!
DISCLAIMER: THIS WILL RESET YOUR PHONE BACK TO FACTORY DEFAULTS! I AM NOT RESPONSIBLE IF YOU LOSE DATA!
If you accept the above disclaimer that your phone will be reset back to factory defaults and I am not responsible for any data, contacts, programs, etc. that you lose, then try this:
Pull the battery and wait 60 seconds
Put the battery back in
Hold down the HOME button and keep it held down
Hold down the POWER button and keep it held down
When it powers up, you should get the triangle with the Android dude
Press the SEARCH button and you should get a menu
In the menu, use your UP/DOWN keys to scroll to WIPE DATA
Once you are on WIPE DATA, press the MENU button
You will be asked several times if you are sure you want to wipe the data - you will need to choose YES and click the MENU button
You will see the triangle again with an arrow coming out of it. Let the phone reset itself back to factory and it should work.
