I recently got a Droid X from a friend of mine. I dont have the legit plans but the monthly type of plan (sort of like Metro PCS). When I connected the phone, everything was fine. Nothing was a problem until I realized that my 3G would go to 1x and then just disappeared. I thought it was just me so I turned off my phone and took out the battery and did all I could. But nothing changed. The connection won't come back. Also, this error would keep popping out, saying that the phone needs to be closed, so when I press okay, it doesn't do anything. It just keeps popping out over and over until I just shut off my screen. So I took it to a cellular store, and they fixed it for me... Or so I thought. It worked fine for a day, then it started again! I started to do some research and other people said to take out the "Advanced Task Killer". However, when I tried to, my phone doesn't have the task killer. So I'm not sure what I'm suppose to do. Some people said that it could be the apps that I have on my phone, but what I don't understand is that I had these apps ever since I had the phone. Even my brother has the same apps as me, but I'm assuming that he doesn't have any problems since he has a different phone. I also tried to "reboot" my phone, but whenever I do, it doesn't seem to be doing anything... I tried everything that I could possibly think of. I don't want to go back to the cellular store, since I wasted money when it didn't fix anything.
Please help, any information will be much of a help to me!
Thank you!
