Ok, I've had dozens of Verizon Phones but something is going really wrong with the Galaxy Nexus that I own. It started out as the best device that I have ever owned. Then I had a problem with it non-related to the signal issues. The tier two tech support had me do a software update on the phone and ever since, the 4G, 3G and phone signal truly struggle. Calls are dropped. Texts wont go through. And internet is often inaccessible. This is all intermittent and untraceable as far as a pattern goes. So Verizon sent me a replacement device. It was worse...to the point that it would not connect to anything reliably, including wifi. They sent me another device and it was more of the same. I am now out of town and having the problems continue with my original phone. A third device is waiting at my house for what Verizon thinks will solve the problem. I'm hoping it is the answer.
Who else is having these problems. Tier Two tells me that this is not a common problem with this phone. It's hard to believe because, I am 0-4 on this device. Also, if you are having problems, did you start having problems in July/August when an update was possibly released?
Let's hear from you!
