After the ICS upgrade to my Droid Bionic, I can no longer connect to my home wifi network. I am using a Netgear WGR416V4 with the latest firmware/software. I am connecting using WAP PSK security. I had a great connection and no issues before the upgrade. After the upgrade I no longer see the "wifi" symbol in the notification bar. Looking at my wifi settings, the connection for my home wifi is constantly looping between "connecting", "connected" and "saved" but there is no connection. I can connect using WEP security, and I can connect at my work using WAP SPK security, but I can not connect at home using WAP PSK security. I've tried wiping the cache and doing a factory reset to my phone. Neither has helped.
Anyone have any ideas?
