For a few weeks I've been having random instances where my tbolt suddenly shuts down. When I try to power it back up, one of 2 things happens:
- After the HTC logo and the Thunderbolt splash, the phone would shut down again. Repeated power-ons would go through both splash screens and power down again.
- Sometimes it would actually boot through to the home screen, but with the red battery indicator and a connect charger message. If i didn't connect the charger within a few seconds, the phone will power down again.
This problem would happen even if I had just disconnected the charger and the battery was nearly full. If I reconnect the charger after it powers down, it powers up normally and shows plenty of charge on the battery. Below is a screen capture of the battery screen use, you can see the tiny red dots in the gaps where I tried to reboot the phone without the charger connected and it thought the battery was dead. Once the charger is reconnected, the phone would boot fine and the battery level would be back up where it was pre-crash:
I did all kinds of tests, starting by uninstalling most of the apps on the phone, which made no difference. Eventually I started to realize a pattern that it would happen more often when I left my home. To maximize battery life, I'm in the habit of turning off unused radios (bluetooth/mobile data/GPS) when I'm home and only use wi-fi, and shut off wifi and enable mobile data when I leave. I am now able to easily replicate the problem by two simple steps:
1) enable mobile data
2) disconnect the charger
That combination will always result in the problem, typically in 1-20 minutes or so. It also doesn't matter if i'm actually doing anything. Leaving the phone sitting on my desk I can watch it shut off, so I have ruled out the "loose-fitting/bulging battery" issue found elsewhere on this forum as a contributing factor.
Without mobile data enabled, I can run on wifi for hours until the battery actually does run down naturally. In the picture below, I used wifi for over an hour, then switched to mobile data, and it shut off right away. Again (if you look close) you can see the tiny red dot indicating the phone thought the battery was near zero when it came back on:
Here's my software info:
