I am able to receive text messages only, but I cannot receive incoming calls or make outgoing calls.
Try turning off the phone, removing the SIM, and waiting a couple of minutes. Then replace the SIM and power the phone back on. If that doesn't work, you may need a new SIM (they're free at Corporate Verizon stores).
