Is there a repeater, signal booster, or something available for Verizon?
It's called a network extender
Also... I'm at work. IT won't allow personal stuff plugged into the network.
Then you're out of luck
It's a Verizon Network extender....not something you plug into your companies network.
http://www.verizonwireless.com/b2c/store/accessory?&action=gotoFemtocell
Simple setup... "Plug into your high-speed Internet connection and place near a window."
Is there another one that you're referring to?
s10stealth wrote:http://www.verizonwireless.com/b2c/store/accessory?&action=gotoFemtocellSimple setup... "Plug into your high-speed Internet connection and place near a window."Is there another one that you're referring to?
s10stealth wrote:
Nope, that's your Network Extender. It "extends" the Verizon "network", not your companies network.
Great question! Yes, we have our awesome Network Extender. Here is some information that will help you decide if this is the best option for you http://bit.ly/AKkC . Are you having an issue with service? If so, what is your zipcode? What phone do you have? Are issues inside or outside? -Kinquana
Maybe you did not understand the OP cannot connect the Network Extender into a broadband internet source, making the item useless.
95742, intersection of Hazel & Sunrise. Indoor issue.
Galaxy S3 still having sticking issues and connection loss while switching between 3G and 4G LTE.
It's not an "understanding" issue. The techs only see key words and then cut and paste whatever answer their check list comes up with. LOL
