A few nights ago I was connected to the internet with my mobile hotspot, I lost connection and noticed the Red LED was flashing.
So far I've tried powered down the unit.
Removed the batery.
Removed the SIM card.
Did a hard re-boot using the button inside the case.
Nothing seems to work, I can see the device from my laptop at home and my laptop from work. When I try to connect it says connected but it is not.
I tried to update the software on the unit from my laptop but it can't find the device, even when it says it's connected?
I also notice the it shows no signal strength on the display, in a place that should have full strength?
It is just over 1 year old, the guy at the Verizon store suggested I upgrade...I can't see upgrading if the equipment will not last the life of the contract.
