Everytime I am trying to get my phone (Incredible) out of my pocket I end up hitting the power key on top and then the call is gone to voicemail.
Is there anyway to stop this feature?
Thanks
kevindun19 wrote: Everytime I am trying to get my phone (Incredible) out of my pocket I end up hitting the power key on top and then the call is gone to voicemail. Is there anyway to stop this feature? Thanks
You are trying to get your phone out when answering a call or just taking it out for any other reason?
Yeah, when it starts ringing I take it out of my pocket and the button gets pushed and I miss the call everytime. IT is real annoying I want it to stop sending to voicemail if possible.
Did you ever consider a case for your Incredible?
I guess I am the only one with this, possible a bad button that is too loose. The case does the same thing, the little button keeps getting pushed
