OK Light Flow problem after update.... the problem is my Talk Back in Accessibility keeps turning on after i restart my phone i know it should not do that it only dose it when i have Light Flow - LED & Notification installed and Tturned on in Accessibility ..... i use Light Flow - LED & Notification to control my LED Notification becuse i hate the built in feature that came with the phone the default management keep the LED to dim hard to see ........ i have used the app ever scene i got the phone and never had a problem tell this crappy update JZO54K.I535VRBLMD3 / I535VRBLMD3 came out i also believe the update JZO54K.I535VRBLMD3 / I535VRBLMD3 that was pushed out made the Accessibility option bad / and everything else
The phone is new
i have hard factory reset it / battery pulled
it did it with old phone but did not do it before that update was pushed
i also got a (NEW) NOT REFURBED phone trying to solve the poor 4G LTE signal /battery life
and over all phone performance with no luck that update was a bad one and needs to be addressed
PLEASE FIX THE PROBLEM >>>>> VERIZON SAMSUNG GOOGLE ( PLEASE )
