This has happened occasionally in the past, and I'd written it off as just a glitch. But over the past few days I've missed several important calls because they went straight to my voicemail without the phone ever ringing, and in some cases I haven't even heard the voicemail alert-tone because it's so short and easy to miss in a noisy environment. The problem seems intermittent and mostly non-specific as to callers -- except that today my sister tried to call me three times from her landline (which I believe is AT&T) and went straight to voicemail each time, but when she called from her Verizon cellphone instead it rang normally and showed her caller ID as usual. So is there something going on that relates to specific sources of calls, or is this a general system issue? And is there a solution? Obviously, I can't continue to miss critical calls this way...
Many thanks in advance to anyone who may respond, especially any Verizon Techs -- please just don't just tell me I'm the only one having this problem and that it must be caused by some improper settings on my own phone (which is a very basic LG Revere model). I haven't changed any settings on it (it doesn't have many anyway), and I've recently updated my roaming software so that shouldn't be an issue either although I'll try again if anyone thinks it might help. The real point is that it's clear a LOT of people have been having this same problem, since I've found at least one long thread on the subject in the forums here and tons of other online postings as well. I'm certainly willing to try any fixes from my end that might be suggested, but the problem seems so widespread that Verizon itself really needs to address the issue from ITS end as soon as possible.
The Verizon forum I found on the topic is at: https://community.verizonwireless.com/thread/780588 -- I've just chosen to start a new discussion here rather than adding to those posts, to avoid having my question buried at the bottom and also because many of the other complainers seem to have smart phones whereas mine is one of the most basic versions around.
Thanks again, for any help anyone can offer...
