Previous to Update: Battery would last a day or two with normal use with Wifi enabled (4/3g disabled)
After update: Battery would last a day or two with normal use WITHOUT Wifi enabled (4/3g disabled)
After update: Battery will last 1/2 day with no use WITH Wifi enabled (4/3g disabled)
Anyone else have similar experience? How did you fix it?
Please don't tell me to "reset my phone" unless you have the above symptom AND it fixed your problem.
I've only had the phone a few months and I'm about ready to toss it out the window. I use Wifi all day long while at work streaming radio/music.
