I bought a samsung wireless charging cover for my note 4. When I tried to out the case on it, it no longer fits. After doing research I confirmed the phone is slightly thicker now. What cases are compatible with this set up?
I apologize joevas22, I didn't mean to insult you; I need to make sure this was done. I researched this quite thoroughly since you mentioned the size had changed. As stated in the link provided, the dimensions are 8inX2inX5in; our model is 6.04inX3.09inX0.33. I assure you, this has been the only model we have and not changed anything. This is the link to the manufacturer's page http://bit.ly/1GbpHCS as well as ours http://vz.to/1ttodxd so you verify the information I provided is accurate. I am not sure why the seller listed the case as compatible with all models. AdaS_VZWFollow us on Twitter at @VZWSupport
I would be happy to find a compatible case for you, joevas22! Did you purchase the charging cover from Verizon? Can you tell us the exact model you got?Thanks, MichelleH_VZWFollow us on Twitter @VZWSupport
Samsung Galaxy Note 4 Wireless Charging Battery Cover - Frost White
I did buy the original samsung qi cover from vzw.com
Thanks for confirming, joevas22! While I'm not showing any cases that are specified to fit this cover, you could consider exchanging for a case that has wireless charging built in. http://vz.to/1sZ5TIx Thank you, MichelleH_VZWFollow us on Twitter @VZWSupport
http://www.amazon.com/gp/aw/d/B00OQB6PLW?cache=5df7a716f57b36fcaad3caa0436474e3&pi=AC_SX110_SY165_QL70&qid=1414897978&sr=8-11#ref=mp_s_a_1_11
The accessories for this phone are delayed for whatever reason. I would get the extended battery once out. It will come with a back plate and last a couple days without charging usually
Michelle, this is the one I bought. http://www.verizonwireless.com/accessories/samsung-galaxy-note-4-wireless-charging-battery-cover-frost-white/
