Since the NG6 upgrade I now have 3 new issues.
1. GPS
The GPS does not work right from the get go when I load up an APP that uses GPS. To fix this I have to Location Services and disable GPS then re enable
to get it to start working. This is highly annoying especially when the GPS tries to fix on the satellitesand causes issue #2 most likely...
2. Battery
Battery life has been reduced by 30% or more. Once I was able to go a full day and night with one single charge and now after the update I can get to the end of a work day then have to charge again with the same usage as before the update. I see the GPS icon stuck in the status bar frequently and this seems to be one of the culprits.
3. Micro SD
Since the update writing to my Micro SD card is no longer an option. This seems to be a Google restriction from what I can tell but why push it down in the NG6 update? Now the phone I have does not perform the same way when I first initially got it.
While I understand updates are needed, poorly tested updates are unacceptable. Being our carrier and with many paying good money for your service I would expect better from Verizon. So I ask you this. What steps are you going to take to resurrect these problems? From searching your message boards I am not the only one with these problems.
-=George
