Don't know if its the S5 or overall service, but the signal I have here has weakened. It use to have full bars but now its half full bars.
Could be a tower issue in your area. Have you tried resetting the SIM card?
Have you checked the performance in surrounding areas of the Town you live in to see if there is any difference's.. You might try that and as suggested you might try removing the Sim Card with the phone in the off position and as a Caution reminder handle the card with care as they're really sensitive to human touch.!
To Add: when you remove the card and reinstall it, it should update the PRL for the phone but sometimes it does not hurt to call customer service and ask what your current PRL is if not updated you might have them update it for you, and if your phone is set to Global you might switch it to LTE /CDMA see if that helps.. b33
