I've finally yupgraded from the S3 which I used at home and work on Wifi with no issue.
I haven't had a stable Wifi connection in proven strong wifi areas (home&work).
What can I do or what is being done to fix this issue?
Try forgetting and adding back the wifi network.
IF it won't connect to any wifi networks, then it may be faulty wifi antenna.
IF still within the 14 days return for a replacement. Otherwise it has to be replaced under warranty.
I've tried that. but no consistent success.
i'm going to try to go back to the store to see if we can get a solution.
unless there are any updates or fixes to try.
