After performing the upgrade yesterday, the auto-brightness is way too low and my battery is draining MUCH faster than normal
As far as the battery goes, it can take several days for the system to relearn parameters according to use. After a few charging cycles and a few days, you should return to normal. If not, a factory reset is advised, especially if you see other problems after this major update.
oh really, where's that in print, I did 5.0 two days ago & my battery ;life is the same.
Why is the auto-brightness now different. I haven't changed it and now the auto is way too low to see anything.
As you may or may not know, many changes take place to each users system as a whole. Each user has different apps and setups. This is true for people who mod or people that have a reflashed or stock phone. This happens straight out of the box as well. There is no absolute in life nor technology and each situation is different. This is even true when using a phone normally. I myself have seen, for instance, my XT912, GNEX, and LG G2 having these issues. It didn't matter what type of battery I had. Right out of the box battery life was not nearly as long as the reported manufacturer specs. Each time I reset the device to factory settings and add or remove certain apps, I can tell a difference for a few days until I complete a few charge/discharge cycles and other apps settle into their routine. This also allows the system to reset its battery statistics for more accurate reporting. IDK how else to explain to you better other than to use my own example, across several devices. I will say that you have been fortunate in this regard versus others with battery life problems after their 5.0 update. You may also see other posts, recently, referring to random reboots, volume levels, calling issues and etc... With multiple issues it is sometimes advised to factory reset. So, suffice to say, it isn't the same for everyone.
kingpin68 wrote: Why is the auto-brightness now different. I haven't changed it and now the auto is way too low to see anything.
kingpin68 wrote:
I don't know WHY it's different, but I can verify that the auto-brightness setting is quite dim. I'm tempted to turn it off as there are times when I literally cannot see what's on the screen.
I had the same issue with crazy battery drain. However my issue was fixed when I updated my security app. I was using Lookout which they admitted to having a battery drain issue. Now that the app is updated, my battery life is almost back to normal. I can typically go 36hours with light use, before need to charge again.
I believe the new way it works is completely different than the way it was before. I am unsure if Samsung made any changes.
On stock Android it is dependent on what your setting is at. If you have it at 50% that is your max. If you have it at 20% that is your max and it scales based on what your max is.
Your battery life may be affect by the memory bug. 5.1 is supposed to address the issue.
my battery life is horrible after the update, I could typically drive to work with GPS and Maps running (Checking traffic conditions - I know how to get to work :smileyhappy:) with it plugged into a charger and be at 100% upon getting to work. Today after the update, I arrived at 87%, 10-20 mins later after sending/receiving 3 text messages (TURNED off GPS and MAPS) my battery is down to 75%. What a joke. Very disappointed in the crazy drain.
I actually went and did a factory reset and it improved everything immensely. Battery life is crazy good again.
burddawg,We understand how important it is to be able to use your device without constantly having to worry about battery life. When you go Settings>Battery what is showing to be using the most of your battery power? What percentage is it showing also? LindseyT_VZWFollow us on Twitter @VZWSupport
