I've had my Galaxy Note Edge since June now and it's STILL using software version N915VOYU1ANL1. Every time I try to do a manual update I get the message that my phone is up to date and no update is necessary. What's going on?
Making sure you have the latest and greatest software is an excellent way for your phone to be working properly. If you aren't showing an update that would indicate that you are all set. We can certainly verify you are on the most recent software though. Can you confirm the version on your phone?MatthewT_VZWFollow us on Twitter @VZWSupportIf my response answered your question please click the �Correct Answer� button under my response. This ensures others can benefit from our conversation. Thanks in advance for your help with this!!
My Phone Reports
Android Version = 4.4.4
Baseband Version = N915VOYU1ANL1
Build Number = KTU84P.N915VOYU1ANL1
HW Version = N915V.04
Security software version = MDF v1.1 Release 5 & VPN v1.4 Release 2
Configuration Version = F14.SAM.SMN915V.0
It's been over 2 months since I posted this question. I haven't gotten any help from Verizon support and my Note Edge is STILL on 4.4.4
Why is my phone not getting the updates it should?
