I downloaded and installed Microsoft Bing on my Droid X from the Verizon section of the Android Market. It installed and works fine, except for one HUGE thing - when attempting to set the end-point (or destination) from the phone contacts, there is NO WAY (that I can see) to select a specific contact! The keyboard does nothing but select the very first contact listed no matter what you type and the contacts seem to be listed in a completely random order - in other words, they are NOT sorted alphabetically. Trying to scroll through more than 700 contacts that are sorted completely randomly is a HUGE problem - this makes Bing's Turn-By-Turn navigation completely useless (in fact, I uninstalled it from my Droid X for this reason)!
I had Bing on my HTC Imagio (Windows Mobile 6.5) and it worked perfectly - to select a contact, you only had to type in part of the contact (name or city, for example).
Anybody else notice this? Did Verizon intentionally do this to encourage you to use VZ Navigator?
Dennis
