I purchased the Home Phone LVP2 to replace my old reliable but expense AT&T landline.
Setup went okay and sound quality okay. However my Panasonic KX-T5432 wireless phones
answering machine would take awhile to hang up after a message was left.
While it was "In Use" there is a fast busy signal that would persist for 10 to 12 seconds which
could be heard and would be recorded as part of the message.
Verizon sent me two new Home Phone devices in the hope that one would properly disconnect my
answering machine. I need to keep the external answering machine to be able to screen calls.
So far all three Home Phone LVP2 devices have not allowed my answering machine to hang up
when the caller hangs up. Has anyone else run into this and does Verizon have a solution?
Verizon ran a diagnostic and said my Panasonic phone appears to be compatible.
Under a Home Phone Connect forum they described the same problem and said it had to do with a "CPC signaling" issue. I read some old postings on a Oooma forum which described this problem and apparently they fixed it 10 years ago!
