I recently upgraded from an Express Card WiFi unit (trouble free for two years) to a MiFi2200. Took a couple of hours with tech support to get this new one activated and working. All was fine until I shut down and restarted the computer. Using the unit as a wireless access point works just fine but trying to use it wired directly via USB (how I most need to use it) it shows "no signal" and won't connect to the Verizon network. Uninstalling and reinstalling VZAccess manager got it back up briefly but another shut down and it's dead again... even after another instal. Meanwhile the wireless access point function works just fine... so there is a good network signal available to the unit.
This is on a MacBook Pro running 10.5.8. While trying to get through the activation Verizon tech support had me download a different version of VZAccess manager. It's shown as version 7.0.5 (build 2424j)
All ideas appreciated...
Bob Smith
