I have had the Motorola Droid since November 2009 and have been streaming audio since then to my car. I believe my car uses BT 2.0 standard. I use mostly Pandora and Slacker. After receiving the Froyo 2.2 update FRG22D I have had consistant problems with the Bluetooth Connection dropping. The connection will drop and I will have to manually go to the wireless settings and click the device to reconnect it. The drop occurs persitantly. It will occur anywhere from a few seconds to 15 minutes after being connected. On a 30 minute car ride I am lucky if I only have to reconnect once. This as you may guess is not safe to do while driving. I have had this problem now for about 3-4 weeks. I have seen a few posts on other sites with the same issue, but no solutions. I have tried reseting the bluetooth pairing and soft reseting ( took battery out for 5 minutes). If a firm reset will fix I will do it, but hate to do it if it won't fix it.
