Low battery life for charge
My wife and I both have the Charge and her battery life is half what mine is, I was hoping that someone would be able to give me a clue as to what I can do to help her battery life. We have put on the 4g lte killer (we do not have 4g), and also put the screen to automatic (same as mine). I am thinking about taking it back because mine is so much better.
Low battery life can be very frustrating. What kind of applications have been downloaded? Did you already return the device?
It is my believe that Samsung has had a bad batch of batteries. Your wife's phone could have been part of this batch. I just recently purchased a Droid Charge and my battery life is terrible. It dies within 6 hours of being unplugged and fully charged with minimal use. Without using the phone at all I managed to get 8 hours out of it. That's without making a single call, text message or even opening a app. It was just locked the whole time. I've spoken with a Verizon rep about this and he said that is not normal. The Verizon warehouse at the time was out of Droid Charge standard and even Extended batteries. So I'll be sent a replacement as soon as they got some in unless I can find a store that has a few in stock first. If I were you i'd take the phone back to the Verizon store and ask them if the battery is defective. From what you are describing to me it sounds that way.
My Charge is EXACTLY the same as yours.... VZ told me that the battery is probably defective. I am waiting for them to send me an extended battery.
I have a Stratosphere and all of a sudden, I am getting hardly any life on my extended battery. I did add Security Anywhere software. Could that be the problem? My first extended battery was deemed defective and I just go a new one. But that one barely last 8 hours with hardly any use. Can the phone itself do something to drain the battery? I am so frustrated.
If you still have both phones, why not swap the batteries and see if the same thing happens with your phone that happend with your wife's? If not, then it's probably her phone (unless she has different apps or a different usage pattern than you). If it does, then it's the battery, and you can return it.
mine last for about 6hrs with call use and data use, texting does not kill it that bad. I thought the normal battery life is about 6hrs?
Based on the reviews, many users were getting 1-2 days of usage. I think it is due to the 4G/3G data connection issues we have been expericing, ie, it keeps searching and reconnecting, draining the battery. While doing nothing, my battery drains roughly 8% per hour, but turning off mobile data, the draining is less than 1% per hour (I still get voice during this time). I blame it on the data connection issues we have been expericieng.
i dont have 4G in my area when i go back to college i will, handles well with 3G though. They need to fix the signal
Cell Stand by 14 percent, display is at 58 percent on for 2hrs battery at 95 percent off charge
Could be the unit itself. I had a unit (first charge ) that woudl deplete the battery when it said charging, it took 2 day to charg to 60%, then woudl die again. Verizon replaced the battery. Same issue.
Replacement unit no issue.
I am on my second Charge. First one got pretty lousy battery life, about half a day. I just looked at mine now and it is still at 59%. I took it off the charger 17 hours ago and have used it periodically throughout the day. Not heavy use, but some browsing, texts and calls. I am in a 3G only area.
Would it be worth while to get a extended battery?
IF you want good battery life then get the official extended with back cover. IT loosk right, maintains the 4g logo, and blends well to the regular form.
To cut back cost on early releases of new models, manufactures give you the minimal required battery. In todays smartones 1600-1800mah batteries jsut don't cut it. Carriers want you to buy the larger batteries to keep you in the stores.
MY store had the 4g logo cover now doesn't. THe extended battery at the store is oddly the same price as the regular 39.99, cover is another 9.00
i see that the battery is in stock but the cover is not in stock
I got the extended battery and now get 2 full days. I like the feel of the phone better as it fits your hand with the little bubble on the back better and it seems less likely to drop it.
To extend the battery charge, consider turning off GPS, turning off the data sync feature for widgets/email, or adjusting the sync duration to update less frequently.
Battery drain can often times be caused by low signal strength when indoors. Your phone's radio works harder to search/connect to the cell tower, thus draining the battery quicker. Office buildings, shopping malls, grocery stores, parking garages -- any hardened or metal construction material can interfere or block cellular radio signals. You may want to turn off your phone's data connection in these environments. With the Charge, you can still enable voice calls while turning off data by long pressing the power button and select Data Network Mode. Or, to shut off all of the phone's radios, select Airplane Mode by also long pressing the power button.
The extended battery is definitely worth it since you don't have to turn off the phone & reboot to swap out the slim batteries.
I just swtich out batterys to see if that was it >.<. Its werid how when the phone is half charge it last for 5 hours lol.
